Difference between fx-8320 and fx-8350?
mjwhelan
199
Would I notice any difference between the models above when playing games like bf3, dayz and skyrim?
When rendering video would there be much difference?
When using CAD would there be much difference?
I am upgrading from an i3 2100 so I want to know is worth spend £160 on the 8350 or £120 on the 8320?
Thanks
as said the 8320 is a lower clocked speed but basically if u can overclock it to the 8350 stock speed of 4ghz it'd basically be the same. The 8350 gets the higher binned chips which can stock run at the higher speeds and still overclock far, where the 8320 comes stock 3.5ghz, and when overclocked may not hit what a 8350 can. Performance wise even at stock there shouldnt be much of a difference in 500mhz. If u feel safe with overclocking and want to get 8350 performance while not spending the few dollars extra going to 4ghz shouldnt be an issue with any decent cooler that isnt the stock one lol
Uther39
Hold on a min, if your upgrading from an i3 2100 then you cannot buy those AMD FX CPUs you have asked about as there not compatible with your motherboard what you need to be looking at is an i5 or i7 and in your budget i would be getting the i5 3570 non K version, but we really do need to know what your motherboard is.
I would agree, if your going to spend $160-190 on an fx cpu plus whatever am3+ board your getting, you could just get a i5 for $200-230 and reuse the board you have. A much easier solution and cheaper
mjwhelan
199
My motherboard for my inter cpu is faulty
lilcinw
833
I bought an FX-8320 about two weeks after release. I looked around for what OCs people were getting from the two and the differences were negligible so I went with the cheaper option.
Once I installed the 8320 I only had to tighten up the load line calibration and bump the voltage a notch for complete stability at 4.4GHz. It has been running Folding@Home at 100% usage ever since without any problems.
TL;DR If you are going to OC anyway there is not a compelling reason to spend the extra cash for the 8350.
8350rocks
If you're going to OC it...buy the 8320 and save some money, spend it on an upgraded cooling system like a CM 212 EVO or something along those lines.
epipslab
33
Buying a cooler that will allow it to overclock, will end up costing the same as the 8350 so just buy the 8350 and then later you will still have the choice to overclock it more than the 8320 can hit.
mjwhelan
199
Thanks for the response mate, Unfortunately a tad late as I bought the 8320 back in march!
Fantastic chip but the only negatives are that the system does feel like it runs as smooth as when I used intel and on a few games the performance is lower than when I used an i3 2100! Exept for those it is a sweet chip when multiple cores work together!
Thanks for your response!
