AMD Ryzen 7 1700 @ 3.7 GHz, GTX 1060, 16 GBs of RAM, and 520w of PSU.
I know the difference between the two in terms of gaming but
What is the difference if I upgrade my gpu to GTX 1070 in 3D/2D Modeling/Animation Software, like Autodesk Maya, AutoCAD, 3DSMax, Blender, Harmony, Flash etc.
Or some editing programs like Adobe Premiere, DaVinci etc.
Also, should I change my PSU to a higher watts? or should I stick with my Seasonic M12II-520 EVO Bronze 80Plus Power Supply 520watts Modular?
Plus, when gaming, my GPU just always use around 5 to 15% all the time, what's the problem with that?
I have a recent problem that my display crashes when rendering a 3D frame using Mental Ray with its highest setting, is changing my GPU will solve that problem? My display is only 1080p @60Hz
