Difference between gtx 750 TI models
MyKeyblader
103
Whats the difference between the:
EVGA GTX 750 TI 02G-P4-3757-KR
EVGA GTX 750 TI 02G-P4-3751-KR
and
EVGA GTX 750 TI 02G-P4-3753-KR
Besides fan number, and does one consume more watts than the other?
The main difference is gpu default clock speeds.
EVGA GeForce GTX 750 Ti FTW w/ EVGA ACX Cooling
1189 MHz Base Clock / 1268 MHz Boost Clock
Total Power Draw : 85 Watts
http://www.evga.com/Products/Product.aspx?pn=02G-P4-3757-KR
1020 MHz Base Clock / 1085 MHz Boost Clock
Total Power Draw : 60 Watts
http://www.evga.com/Products/Product.aspx?pn=02G-P4-3751-KR
EVGA GeForce GTX 750 Ti Superclocked
1176 MHz Base Clock / 1255 MHz Boost Clock
http://www.evga.com/Products/Product.aspx?pn=02G-P4-3753-KR
All will perform within 5-10% of each other with the standard card (EVGA GTX 750 TI...
They are all the same chip, so they will consume the same watts. The difference between them is in clock frequency and the cooler. The dual fan card, 750Ti FTW, comes with the highest factory overclock, and will be the fastest one out of the box. You could probably overclock the lesser ones to the same clock speeds, but overclocking is never guaranteed. If there isn't a huge price difference, I'd go with the FTW version. Otherwise there shouldn't be more than a 5% performance difference between them in most cases.
All will perform within 5-10% of each other with the standard card (EVGA GTX 750 TI 02G-P4-3751-KR) being the slowest.
Latest posts
