Difference between intel Duo core and Intel 2-duo
Core2 duo changed the design of the chipset; runs cooler. P4's have hyperthreading support, but it's not the same as running with 2 cores. You must check the "cpu support" section before purchasing any board to be sure it will work, and see if a bios update is required for the newer cpus listed.
_zxzxzx_
459
36
If you're talking about Intel's Core Duo and Core 2 Duo then the Core 2 series is a newer generation with a slightly different architecture and overall better performance.
Similar threads
