If i want to bye a led monitor instead of a tv then what will be the problem when i will use it as a tv ? Is it possible, angle of view of an led monitor is 180 degree as like led tv ?
Thanks.
a television typically has more inputs than a computer monitor. you might not find all the inputs you are looking for (for instance component video) on a monitor that you may find on a television.
monitors do not have tuner cards, televisions do.
display properties are determined by panel type. IPS type panels do have 178-179 degree viewing angles.
