Difference between Lite and standard PSU’s
Jul 7, 2018
12
What’s the difference between Corsair lite and standard corsairs Power supply’s? Does the ‘lite’ means it’s pyhscially not as heavy?
There's a big difference. The Masterwatt (not lite) is much better, and alright budget unit. The Masterwatt lite usually isn't worth considering.
They are made from different OEMs - Enhance on the Lite, HEC on the other. The Lite uses group regulation on the secondary side while the MasterWatt uses DC-DC. The Lite will have worse electrical performance and build quality.
Review for the MasterWatt: https://www.computerbase.de/2018-03/cooler-master-masterwatt-enermax-revobron-netzteil-test/2/
Review for MasterWatt Lite: https://www.computerbase.de/2017-07/cooler-master-cougar-xfx-zalman-netzteil-test/2/
