Difference between low and high-density SDRAM?
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.chips (More info?)
I'd like to add a used PC100 or PC133 256MB DIMM to my AOpen AX6BC
BX440. It requires low-density: how can I discern the difference
between low and high-density (I have the mobo manual, and believe I
have a handle on the other spec requirements and compatability
w/existing 2x128s)? Thank you
In the "normal" sense of "low density" it would mean the inidivual capacity
of each chip - a 440BX mbrd can use chips up to 128M-bit, so you need to
make sure that the DIMM you buy is double-sided with 16 chips.
A while back, there were also DIMM mfrs selling "high density DIMMs", a
term they coined to describe a DIMM made with memory chips with a data
width of 4-bits. They also had 16 chips and were populated on both sides
of the module but are configured as a single 64-bit wide row/rank of
memory. The 440BX does *not* support such a configuration so, as well as
the 16 chip count, you need to be sure that the memory chips are a 16Mx8
configuration and not 32Mx4.
The best advice is just to go to www.crucial.com and plug your mbrd
name/model into their selector. Their prices are reasonable and they will
not sell you a dud or mismatch.
Rgds, George Macdonald
"Just because they're paranoid doesn't mean you're not psychotic" - Who, me??
In the SDRAM days, they came up with the term low-density vs.
high-density to describe the difference between DIMMs with memory
modules on only one side of the module vs. those that have them on both
sides of the module. Now, you could have 256MB of RAM entirely on one
side of the module, or 256MB split half between the front and back of
the module.
The single-sided was considered "low-density", despite the fact that it
has packed 256MB into half the number of chips as the dual-sided module.
Most of us would normally call a chip with a higher number of circuits
to be higher-density, but in this case they aren't referring to the
internal electronic density, but the just the density of the number of
chips. The reason this is important at all is because those
"high-density" modules, having more chips on them, drew a lot more
power, many motherboards couldn't supply the required amount of power to
those types of modules. Or if they could, they could only supply them to
one module, but not more modules.
I'll echo what others have told you about going to Crucial.com, but also
add you might want to check out Kingston.com, they both have online
forms which allow you to choose precisely what type of modules are
certified for their particular motherboards.
Yousuf Khan
> the module.
I'm sorry but that is not right.
Chips on one vs two sides was called single and double sided, which is also
confusing because, while it was physically true for the early chips (and
'common'), it really refers to having two 'groups' of chips with each
'group' being 64 bit wide. I.E. a double 'sided' module could still have
all chips on one physical side of the module. What made it 'double' was
having two 64 bit wide 'groups', as in 2 groups of, say, 8 meg x 64, which
would give 128 Mbytes total. The two groups are addressed as if they are
two (single sided) sticks even though in the one socket, which is why the
board must support double sided sticks. The actual physical layout is
irrelevant, other than the practicality of assembly, since the electronics
has no way of even knowing where they're located, much less care.
The term 'density', as it is used in this context, relates to the chip
organization.
As noted above, the data bus is 64 bits wide. If the chips are organized
8x8 (64 Mbit) then 8 of them make up what I called a 'group' (I'm avoiding
"bank" because that's used internally for a completely different thing).
I.E. 8x8 chips, times 8 of them, is 8x64 for 64 Mbytes. Put two groups on
the stick and you get 128 Mbytes, as in the above example for "double sided."
Now, one way to think of 'high density' (and the one they mean) is to be
able to get more Mbytes per 64 bit wide 'group'. And one way to do that is
to organize the chip as 16x4 instead of 8x8. Same number of bits in the
chip (64 M, so *IT* is the same 'density') but it now takes 16 to fill the
64 bit wide 'group', because they are each only 4 bits wide, for 128 Mbyte
on the 'single side' (twice as much. e.g. 'high density'). Note again that
physical location is irrelevant and if you can figure out how to get 32 on
the stick you could have a 256 Mbyte 'double sided' module.
The problem is it takes an additional address line to address a x4 chip vs
the same size x8 so if the motherboard expects 8x8 chips, and has only that
many address lines, then it will only see half of a 16x4 chip. It needs the
'low density' 8x8.
Now, the thing we all are familiar with because it's 'in the spec' for the
motherboard is a statement like "supports 256 Meg RAM modules" or "supports
768 Meg (total)". That presumes the chip organization that was 'standard'
at the time since that would be all they knew about. So putting a 512 meg
module in a 256 meg socket won't work because it can't address a module
that large and putting in a 256 Meg 'high density' module will result in
only half being seen, or not work, for a similar reason: it can't fully
address the x4 chips being used. (there can be other differences, such as
chip banking and refresh rate, but this is enough for the gist of it)
I imagine it'll be fine for his board but I've noted they're not always
right. I have an original issue BH6 rev 1.0, BX440 chipset, and most
'selection guides' claim it supports 256 Meg per socket and 768 meg total,
but it doesn't. It only supports 128 meg per socket, 384 total. It's the
BH6 rev 1.1 that supports 256 meg sticks, but they don't distinguish
between them.
> Yousuf Khan
>BX440.
Out of curiosity, how much do expect to pay?
Oh in advance [playing].
It's all relative to what's available at that time I think. Double
sided DIMM should be using "low" density chips for that period of
time. The density refering to the mbits per chip, so lower density
requires more chips per DIMM to make up the same amount of RAM.
L.Angel: I'm looking for web design work.
If you need basic to med complexity webpages at affordable rates, email me :)
Standard HTML, SHTML, MySQL + PHP or ASP, Javascript.
If you really want, FrontPage & DreamWeaver too.
But keep in mind you pay extra bandwidth for their bloated code
magic_philter@hotmail.com wrote:
> This looks like the same issue I am dealing with
> I am looking to put a 512MB DIMM in my ASUS CUV4X-E
> It supports 1.5GB in 4 slots (max 512MB per slot)
> I am located in Canada, and I don't want to bring the RAM across the
> border, so I am trying to determine whether the board supports
> high-density chips, as they are more inexpensive!
> Crucial.com says these chips will work:
> 512MB - CT64M64S4D7E SDRAM, PC133 · CL=2 · Unbuffered ·
> Non-parity · 133MHz · 3.3V · 64Meg x 64
> 512MB - CT64M64S4D75 SDRAM, PC133 · CL=3 · Unbuffered ·
> and some other sites I have tried tell me that the board supports 16x8
> or 32x8 configurations with a CAS latency of 2.
> My local parts store has 2 different modules, low or high density ( I
> haven't seen the sticks to count the modules) - does any of the info
> above tell me if this board will support HD modules?
> Thanks!
The 16x8 and 32x8 chips are what's used on the 'low density' modules and
that's what you need. A 512 Meg module would use 16 32x8s.
Note, many listings will show the 'high density' organization (x4) being
compatible with the chipset on your board, and they are, EXCEPT FOR ASUS. I
mention that in case your local shops are not familiar with the Asus
'exception'.
So the specs for the RAM you want would look like:
PC133 512MB,168 pins DIMM SDRAM NonECC 'low density'
32X8 (The memory chip organization: 256Mbit 32x8, low density)
16 Chips (Simply a 'must be' for it to add up. 512/32 = 16)
3.3V
CL3 (or CL2)
NonECC
Note, the x64 numbers you see, like 32x64 or 64x64, are merely the memory
size and rather redundant as the bus is always 64 bits wide. It is NOT
telling you the density. That is in the x4 (high) or x8 (low) chip type.
>> the module.
>organization.
It's been used interchangably for both.
What you are calling "group" has been called "row" by Intel in their docs
in the past. The term "rank" seems to be accepted if not preferred now.
Some DIMM mfrs used this nomenclature but they were bottom-feeders, notably
SyncMAX. In fact they were using (surplus ?) chips normally used for high
capacity 32-chip registered DIMMs in unbuffered 16-chip single-rank DIMMs.
>'low density' 8x8.
IIRC the addressing was never a problem; VIA chipsets generally "supported"
the x4 chip configurations and in practice, often only with one or two
DIMMs inserted in the mbrd - a third DIMM would not work due to signal
loading and SyncMAX had tables of "motherboard compatibility" demonstrating
this. Intel's 440BX and other desktop chipset docs specifically ruled such
configurations out as placing too much load on the signals - Intel never
approved x4 memory chips for any of their desktop chipsets which used
unbuffered DIMMs and had spec updates which covered this for some... IIRC
the 430VX was one.
>between them.
Hmmm, according to Intel docs, the 3-DIMM mbrds didn't have to have FET
switches and some early 440BX mbrds didn't have them - could be the reason.
>>>the module.
>>organization.
That's why I clarified what context I was using.
Yeah. And it's also commonly called bank, consistent with the previous SIMM
'bank' terminology.
I just thought 'group' would be intuitive enough for the average reader.
I've seen the term used quite a bit, not just SyncMAX (whoever they are).
For example, do a search on pricewatch for "single sided" and you'll see
Spectek, Corsair, Infineon, and Muskin listed. (I picked single sided
because that's the 'rare' case)
My MS-5169, BH6, P2B-VM, BP6, and D6VAA user manuals all say they support
single and double sided DIMMS.
Same terminology with 72 pin SIMMS. As my ancient AN4 Green 486 motherboard
manual states for the code key "(S) Single Sided 72pin SIMM, (D) Double
Sided 72 pin SIMM)
>>'low density' 8x8.
That's why the most common symptom with a 'high density' module in a
motherboard that doesn't support it is seeing only half the memory.
Yes, the VIA chipsets do (133a and 694). Asus motherboards using those
chipsets being an exception.
> this.
I really don't know anything about 'SyncMAX' or what funky things they were
doing.
> the 430VX was one.
Using x4 chips doesn't put any more chips on the individual signal lines
than using x8 does. Are you saying an x4 chip is just inherently a 'heavy
load' for some reason?
>>between them.
It isn't a loading issue as far as I can tell. If I plug a 256 meg stick in
I get 128 meg, which works just fine but isn't particularly helpful.
The mobo specs are unambiguous. BH6 v1.0 max memory size is 384 Meg. BP6,
with the same BX chipset, is max mem size 768 Meg. BH6 supports max 128 Meg
DIMMS and 3 x 128 is 384. The BP6 supports 256 Meg DIMMS and 3 x 256 is
768. If I take the exact same three 256 Meg sticks out of the BP6 and plug
them into the BH6 I end up with a perfectly fine and functional 384 Meg.
One can address twice as much as the other, in the socket and in total.
Btw, since you brought up the BX data sheets, it states "Supports up to 4
double-sided
DIMMs."
> 'bank' terminology.
Please. Call it a rank.
Not "group", not "bank".
The last time I looked to buy a Dell box, the DRAM config asked me if I
wanted 1 GB of memory with 2 ranks or 4 ranks. The costs are different.
Using lower number of ranks preserves some upward expandability.
> > the 430VX was one.
You need twice the number of DRAM chips on the module if you use x4
devices as opposed to x8 devices. Since the address is sent to every
single DRAM device on the memory module, more DRAM devices means
heavier loads on the address lines, and that load is 8 or 16 devices
per line if not more.
This is one reason why DDRx SDRAM devices still needs a "full cycle" on
the command and address busses while the data bus can be cranked up to
2x the data rate. The loading there is limited to ~4 loads. It will drop
to 2 loads as data rates continue to climb.
davewang202(at)yahoo(dot)com
>>'bank' terminology.
>>>the 430VX was one.
Ah, right. Of course. I was myopically thinking of the data lines.
Not sure what you mean here - single sided means (to me and I thought
everbody else) 8/9 devices per module on oe side... just like the Crucial
512MB DIMMs I bought 3weeks ago. Those 16-device thingies are non-standard
configs which do not conform to Jedec rules.
I would not advise trying to use x4 device DIMMs on any Intel chipset mbrd
- just one *might* work but Intel has "outlawed" them - read the docs.
<<snip>>
No experience there but there were sufficieent address lines on all the
Intel chipsets I recall reading the docs for - Intel comments on this just
before ruling them out on bus loading grounds.
>> this.
>doing.
Their Web site is not hard to find.🙂
>> the 430VX was one.
Yep - as soon as the overloaded, because it's driving double the chips it
should, Chip Select is "latched", and assuming it can be, the address lines
are also driving 16 chips.
Yes.
>double-sided
>DIMMs."
Yes but *WITH* FET switches to buffer the signals. For the 3-DIMM setup
they're not required, according to the original data sheet, but I suspect
that they were used on later 3-DIMM boards.
What I mean here, and am demonstrating with the examples, is that the
terminology 'single and double sided' is not some oddball thing from a few
'bottom feeders' but, rather, a widely used industry terminology.
That *is* what most people think because it is usually coincidental, and is
what inspired the usage, but the motherboard can't tell, much less care,
where the chips are mounted and there is no need for a motherboard to
'support' where someone places the chips.
What single/double sided really means is, in the modern parlance, whether
the module has 1 or 2 ranks or, in another common parlance, 1 or 2 rows or,
in another common parlance, 1 or 2 banks.
I didn't say anything about x4 devices. Those are simply more examples,
this time from the motherboard manufacturer side of the equation, of the
common single/double sided terminology.
> <<snip>>
Well, it isn't just a matter of 'address lines', the chipset has to support
the chip organization in it's multiplexing.
>>>this.
>>doing.
No doubt. But since I don't have any of their modules it didn't seem important.
>>>the 430VX was one.
Yes, I was thinking of the data lines and not the address. My boo-boo
> Yes.
Yes, what?
The 128 meg vs 256 meg stick issue is with equal numbers of 8x8 vs 16x8
chips. The loading is the same but 8x8 works and 16x8 don't.
>>double-sided
>>DIMMs."
Right. But '4 sockets' has nothing to do with the point I was making. It's
simply another example of the 'single/double sided' DIMM as common industry
usage, this time from the Intel BX data sheets. They're saying it supports
up to 8 ranks as 4 - 2 rank (I.E. double sided) modules.
> but I suspect
Perhaps, but that doesn't alter whether it supports 16x8 chips or not.
<sigh> Single sided means 8/9 chips on one side of a module, with the other
side unpopulated - nothing oddball. What *is* oddball is the 16-chip
unbuffered DIMM made with x4 chips, populated on both sides as a single
rank - what you, and some unscrupulous DIMM "mfrs" call a "high density"
module.
What I've been saying all along. Lets' be quite clear here: the 16-chip,
single rank, unbuffered DIMM does *not* conform to industry standards -
it's a bastard child.
Yes you *DID* mention x4 devices and it's still up above in the 1st quoted
para where you talk of chips which are "16x4" and "only 4 bits wide"...
exact quotes!!
>> <<snip>>
Read the Intel chipset docs and maybe it'll be clearer to you.
>> Yes.
>Yes, what?
Yes it's a loading issue - read the docs.
>>>double-sided
>>>DIMMs."
No, just read the Intel 440BX data sheet. The 4-DIMM/8-rank config *must*
have FET switches because of loading considerations.
>> but I suspect
It matters as to how many 64-bit wide, 8-chip memory ranks you can put on a
mbrd reliably.
I've already explained this. The physical location is a common coincidence
but is not what matters to the electronics. 'Single sided' means 1 rank on
the module and 'Double sided' means 2 ranks on the module.
> module.
Has nothing to do with 'me'. I don't make them and I don't dream up the
terms. I'm just explaining what's out there.
No, what you just said was it meant the physical location of the chips.
That's the common coincidence, and the origins of the unfortunate
terminology, but it isn't what matters to the electronics.
That is a different matter than single vs double sided. You keep mixed the
two topics together but they're separate.
> exact quotes!!
Not in the context of what double/single sided means and it being common
industry usage.
Whether a board supports the x4 chips is a completely different topic than
talking about single vs double sided and THAT was the topic when I listed
the memory manufacturers and motherboards mentioning single/double sided
support.
>>><<snip>>
Maybe you should read it and then the chip organization will be clearer to you.
>>>Yes.
>>Yes, what?
If you ever read what the hell was written you'd know it's not. x4 has
nothing to do with the BH6 128 meg vs 256 meg issue.
>>>>double-sided
>>>>DIMMs."
Good grief. Read the above paragraph again. "4 sockets has nothing to do
with the point I was making" and here you are screaming about 4-DIMMs again.
>>>but I suspect
> mbrd reliably.
Which might be relevant if ANYWHERE I had mentioned trying to shove 8 ranks
into 3 sockets.
The 128 meg vs 256 meg stick BH6 issue is with equal numbers of 8x8 vs 16x8
chips. The loading is the same but 8x8 works and 16x8 don't. Just ONE stick
of 2 ranks.
FET switches makes NO difference for ONE stupid socket and 16x8 is NOT a 4x
loading issue.
Latest posts
