I researched this myself but all i found was marketing BS. like the inclusion of extension cables, rubber vibration gaskets, "low noise" cables (aka performance killers) with the newer A14 model. they also said they improved the bearings from SSO to SSO2 on the newer A14 models, by moving the rear magnet 1mm or so closer to the rotor axis for more stability, but I don't buy that. stability has never been an issue on premium fans from any brand.
the specs are almost identical in terms of Static Pressure, Noise, and Airflow. but the A14 model costs $11 more. I need to buy 6 fans so it will cost me $66 extra if i go with the A14 model.
it seems to me that that the only benefits for buying the newer/more expensive will be the inclusion of the accessories that i have no use for and the poop brown + vomit tan color scheme? am i wrong?
thanks
thanks
