Question Difference between normal and oc card
Mar 1, 2019
Hello, There are 2 palit cards,
GeForce RTX™ 2060 GamingPro OC
and
The only difference is clock boost, and that is 150mHz higher in oc version.
But wouldn't be it the same, if I just bought normal version and manually over clocket it to that value? Why there's difference in price?
Graphics card vendors bin their chips and use the better ones in factory overclocked versions
that they can sell for more. You may be able to OC more, but then again, perhaps not.
They try to differentiate by adding cosmetics and fancy coolers which also sell for more.
I do think you get fair value from a modest factory overclocked card.
If you need more performance, they buy a higher tier card in the first place.
Similar threads
