Difference between numbers and letters on RAM
karineloo71.kl
What's the difference between an 11-12-A1 and an 11-13-A1 RAM? I want to buy a new one, and thats the only difference between the two.
Looking at the first example, 11-12-A1:
The first number (11) represents the CAS Latency - CAS Latency in clocks at maximum operating frequency
The second number (12) represents the SPD Revision - JEDEC SPD Revision Encoding and Additions level
The third number (A1) represents the Gerber File and Revision - JEDEC Reference design file used for this design
According to SK Hynix's label info for DDR3.
