Difference between RTX 2060's?
darebt123
Commendable
Jan 12, 2019
79
5
1,535
Hi, I would like to get a RTX 2060, but I wonder what is the difference between the brands, for example why does it have 2 instead of 3 coolers if it has the same clock speed, or even better boost speed for the EVGA cards for example and they go with 2 coolers as well.
https://www.newegg.ca/Product/Product.aspx?Item=N82E16814932120&Description=RTX%202060&cm_re=RTX_2060-_-14-932-120-_-Product
https://www.newegg.ca/Product/Product.aspx?Item=N82E16814137380&Description=RTX%202060&cm_re=RTX_2060-_-14-137-380-_-Product
https://www.newegg.ca/Product/Product.aspx?Item=N82E16814487424&Description=RTX%202060&cm_re=RTX_2060-_-14-487-424-_-Product
https://www.newegg.ca/Product/Product.aspx?Item=N82E16814126280&Description=RTX%202060&cm_re=RTX_2060-_-14-126-280-_-Product
Here are 4 of the products I have found on newegg.ca, I was gonna go with the Gigabyte one since it has 3 coolers, i presumed it would be OCed higher?
I noticed they all have the same boost speed of 1830 Mhz, Except for the ASUS one, the second.
Anyways, I'l probably order the Gigabyte,
Thanks!
