Difference between SSD and 7200 rpm
freshbuilder
182
What's the difference in loading times between a 7200 rpm drive and an SSD? friend of mine says that its not worth it since the difference is only a couple of seconds. furthermore, i read an article that SSDs lose performance over a certain span of time.
If you are benchmark junkie, you will drool over an SSD. Here's a real life measurement in same box .... w/ Vertex 3 Max IOPS (Tier 3 = fastest available for 120GB size) on SATA 0 and Seagate Barracuda XT (one of the fastest 7200 ro HD's) on SATA 1. I can select which one to boot off of from the BIOS
http://www.tomshardware.com/reviews/buy-ssd-recommendation-value,3088-6.html
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=708&Itemid=60&limit=1&limitstart=10
Boot Time from SSD = 15.6 seconds
Boot Time from HD = 21.2 seconds
If the 5.6 seconds gets ya blood pumping, you should invest in a SSD.
If ya wanna see where the near future lies, I agree with the author here...
Energy96
276
I could never ever go back to using a HDD over an SSD. The change in experience is that drastic.
The only reason not to get an SSD is if you cannot afford one.
Don't get an SSD over a better video card or processor, but if you are already getting what you want and can spare the cash the choice is simple.
HDD's will be virtually extinct in 5 yrs or so.
If ya wanna see where the near future lies, I agree with the author here.....
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=806&Itemid=60&limit=1&limitstart=9
I really like where the Seagate Momentus XT series is heading, because I firmly believe all-in-one hybrid storage solutions are the future... at least until NAND flash components can cost as much as mechanical counterparts. Multi-part hybrid solutions with 3rd party software, such as those currently promoted by the competition, are hardly a match for integrated hybrid products like Momentus XT. Now grown to offer 750 Gigabytes of storage capacity, the new second-generation Seagate Momentus XT is offering the best of both worlds better than anyone else.
The Momentus boots to Windows a second slower (17 secs) than the dedicated SSD (16 secs)
http://benchmarkreviews.com/index.php?option=com_content&task=view&id=806&Itemid=60&limit=1&limitstart=7
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148837
Not a bad price at $250 when a 120GB SSD and 500 GB HD goes for $285ish
