Difference between the Razer Kraken and Kraken Pro (or "advice on buying a new headset")
Chevy_Monsenhor
102
I was taking a look on some headsets , since my Microsoft LX-3000 blew it's speakers.
My cousin said she likes the Kraken , from Razer, she says it's a real good set.
But there are two main models available , the standard Kraken and the Kraken Pro.
Besides the microphone (something i don't use) , is there any difference between the two?
And , if the Kraken is not a good deal , is there any headset you could recommend?
Thank's since.
Chevy.
Kraken USB requires USB port, 32mm Drivers, poor Mic, lack of Mic features and control.
Kraken 7.1 is USB, 40mm Drivers, Digital Mic
Kraken Pro is same quality and features as the 7.1 above; but is Analog, not USB.
These are better in my opinion, more comfotable, better overall sound, inline volume control and not Fugly colors.
HyperX Cloud Gaming Headset $69.99
Pros
Amazing sound for under $100 not as good as the Siberia v3 but better than the v2
Comfortable
Inline Volume Control
Cons
Lacks digital noise cancelation, cups over your ears which does a decent job of filtering noise.
Craptastic Mic.. it works but very staticy...
Pros
Comfortable
Cons
http://www.amazon.com/gp/product/B00JJNQG98?tag=ttr_gaming_headsets-20&ascsubtag=[site|ttr[cat|852[art|NA[pid|62081[tid|NA[bbc|NA
SteelSeries Siberia v3,v2 $77, $50
Pros
Amazing sound A step up from the v2 which was very good, much more response and Bass you can feel
Very Comfortable
Cons
Lacks digital noise cancellation, cups over your ears which does a decent job of filtering noise.
http://www.amazon.com/SteelSeries-Siberia-Full-Size-Gaming-Headset/dp/B003N636VI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1428197265&sr=1-1&keywords=SteelSeries+Siberia+v2
http://www.amazon.com/SteelSeries-Siberia-v3-Gaming-Headset-White/dp/B00O06ZMD0/ref=sr_1_1?s=electronics&ie=UTF8&qid=1428196899&sr=1-1&keywords=SteelSeries+Siberia+v3
