Difference between these Rams?
Andrew_C1
130
Looks like they're clocked differently. One is DDR4-3200 (3200MHz) and the other is DDR4-3000 (3000MHz).
I can't think of a performance difference that small difference in speed would make, so the modules are practically identical.
Even the timings and voltages are the same - 16-16-16-36 and 1.35V.
Don't beat yourself up. Honest mistake.
So I might as well go for the 3200 then? They're pretty much the same price anyway.
That's what I would do. Unless your motherboard caps out memory speed at 3000MHz, then there'd be no point.
I added some additional info too.
Latest posts
