M MaxRabbit Distinguished Dec 3, 2007 123 0 18,680 Dec 4, 2007 #1 What is the difference between the S3L motherboard and this DS3L motherboard? The only thing I can find is the memory standard
cfvh600 Distinguished Oct 8, 2007 993 0 18,980 Dec 4, 2007 #2 MaxRabbit : What is the difference between the S3L motherboard and this DS3L motherboard? The only thing I can find is the memory standard The price is also different. 🙂
chookman Distinguished Mar 23, 2007 3,319 0 20,790 Dec 4, 2007 #3 Weird dude. According to the dimensions the GA-P35-DS3L is actually smaller as well??? But looking at the pictures it doesnt look smaller
M MaxRabbit Distinguished Dec 3, 2007 123 0 18,680 Dec 4, 2007 #4 Hmm; from looking at pricegrabber.com, shopzilla.com, amazon.com, and buy.com, newegg is the only site that has the S3L Very odd.
O okanimy Distinguished Apr 22, 2007 9 0 18,520 Dec 4, 2007 #5 The difference is the type of capacitors they used. S3L uses old capacitors, while the DS3L uses solid capacitors. They're supposed to be more durable and lasts longer. http://www.gigabyte.com.tw/FileList/NewTech/2006_motherboard_newtech/article_02_all_solid.htm
M MaxRabbit Distinguished Dec 3, 2007 123 0 18,680 Dec 5, 2007 #6 Oh, I see (though that source doesn't say that the DS3L uses solid capacitors-how did you know?) I have another question-how can I know which revision of motherboard I would be getting? Thanks for your help.
