What the difference between WDs Blue 2.5" and Scorpio Blue HD's? Im having a really hard time finding the answer to this. Their site seems to only list scorpios. Im replacing the HD in my old fat PS3 and heard the scorpios work pretty well in there
for example im looking at these two hds
WD5000LPVX Blue
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236498&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=1312731&SID=
WD5000LPVT Scorpio Blue
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236240&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=1312731&SID=
I cant tell what the difference is between the PVX and PVT. THe only difference i see is the PVT is labeled as a 'scorpio blue' and the PVX is just labled as a regular 'blue' The specs seem the same. Though i think this particular blue is only SATA 3.0 and the scorpio/PVT is 6.0.
So hopefully someone can fill me in on the difference between the blues and scorpio blues. The regular blue is on sale for 15% off through tomorow so if theres no real difference ill get that one
WD5000LPVX Blue
