Difference in performance between PC's
MankeyDLewfy
27
I've recently seen a PC build that is not only cheaper than my original but also has decent performance in games such as GTA V and Witcher. There is a noticeable difference in price between PC's and made me question which I should buy. I would like to know which I should buy by performance for gaming and also productivty. If you can also say the difference between the two that would be great. If there is anything you can change for the 2nd build staying under $600 go ahead. This is the video for the 2nd build showing some benchmarks(also keep in mind I made some changes in the cpu and video card so it will be better for gaming) http://youtu.be/vuhbtlHL3Og
1st Build (more):
PCPartPicker part list: http://pcpartpicker.com/p/GwPnxr
Price breakdown by merchant: http://pcpartpicker.com/p/GwPnxr/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($159.99 @ SuperBiiz)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard ($68.20 @ SuperBiiz)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory ($47.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC)
Video Card: MSI Radeon R9 380 4GB Video Card ($209.98 @ SuperBiiz)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case ($79.98 @ Newegg)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply ($52.98 @ Newegg)
Total: $669.00
Generated by PCPartPicker 2015-11-26 23:49 EST-0500
2nd Build(less):
PCPartPicker part list: http://pcpartpicker.com/p/QZwgGX
Price breakdown by merchant: http://pcpartpicker.com/p/QZwgGX/by_merchant/
Motherboard: ASRock B85M-DGS Micro ATX LGA1150 Motherboard ($41.65 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($35.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($39.10 @ SuperBiiz)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($29.99 @ Newegg)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter ($34.00 @ SuperBiiz)
Other: EVGA 500 + ($35.99)
Total: $586.69
Generated by PCPartPicker 2015-11-26 23:50 EST-0500
I happen to like the parts in the first build a little better (in regards to performance and reliability) based on my experiences with the brands and reviews from others. Like I said, just my opinion. The card is a 2 GB rather than a 4 GB, but the difference in performance (at 1080P) would be minimal compared to the difference in price.
