difference of b450 aorus pro and pro wifi
The B450 Aorus Pro Wifi has Wifi and bluetooth on the motherboard installed, where the B450 Aorus Pro has not.
But the B450 Aorus Pro is more modern than the B450 Aorus Pro Wifi and you can always install a wifi card with an bluetooth usb in your pc.
You should get the B450 Aorus Pro and not bother with wifi that much. use cabled network, unless you don't have one, still get the B450 Aorus Pro and then a wifi card.
They are literally the same board with one having wifi and the other not having wifi. You can compare the specs here and see that there is no difference other than wifi and bluetooth:
Pro -https://www.gigabyte.com/Motherboard/B450-AORUS-PRO-rev-10#sp
Pro Wifi -https://www.gigabyte.com/Motherboard/B450-AORUS-PRO-WIFI-rev-10#sp
Buy which ever one you want. If you care about built-in wifi then get the wifi. If not, and you want to use a cabled connection then go for the regular Pro. Or, get which ever one is cheaper.
