[SOLVED] Differences between same motherboard models with different providers
Dec 1, 2021
11
Hi Guys,
I'm going to buy an AMD x570 motherboard, but there are so many variants.
My main requirement is to have the max and best perfomance from 2 SSD NVME and AMD Ryzen 9 5900X.
This are all x570 motherboards:
  • MSI MEG X570 UNIFY
  • MSI X570-A PRO
  • MSI X570 TOMAHAWK
  • MSI MEG X570 ACE
  • MSI X570 MPG Gaming Edge
  • MSI MPG X570 GAMING PLUS
  • MSI MPG X570 GAMING PRO CARBON
  • Gigabyte X570 Aorus Xtreme
  • Gigabyte X570 AORUS ELITE
  • ASUS ROG Strix X570-F Gaming
  • ASUS ROG CROSSHAIR VIII EXTREME
  • ASUS TUF X570-PLUS
  • ASUS Prime X570-PRO
Which one should I choose?
Does each one support 2 nvme at full speed and Ryzen 5900X?
Which one do you suggest for price/value?
Just to narrow it down.
The mobo must have at least 2 m.2 slots that support pcie4x4.
This one is good...
PCPartPicker Part List
Type|Item|Price
Motherboard | Asus ROG Crosshair VIII Dark Hero ATX AM4 Motherboard | €511.99 @ Amazon Italia
| Prices include shipping, taxes, rebates, and discounts |
| Total | €511.99
| Generated by PCPartPicker 2021-12-02 16:28 CET+0100 |
Storage
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors :
AMD Ryzen™ 4000 G-Series/ 3000 G-Series/ 2000 Series/ 2000 G-Series Desktop Processors :
1 x M.2_1 socket 3, with M key, type 2242/2260/2280 storage devices support (SATA & PCIE 3.0 x 4 mode)
8 x SATA 6Gb/s...
Not all boards will be priced the same in all regions, which leads me to ask where are you located? As for the boards listed, what are you looking for apart from the storage? Why do you need 2 SSD's to run at their best? Also, you should be looking at higher end boards from that list, meaning the ones that are priced higher since the componentry on the VRM will be of higher quality...to say the least. People investing in a Ryzen 9 5900x aren't going to be leaving them at stock clocks.
I'd stay away from the Strix's, the TUF's and Prime's from Asus and the Gaming lineup's from MSI.
You're also overthinking using RAID 0 with PCIe 4.0 SSD's.
I'm in Europe/Italy.
The other thread made me realize that I don't need a RAID 0, but I'm going to use an NVME for boot and an NVME for a blockchain node, so I'd like to have both at full speed.
Other requirements are just a DDR4 RAM > 32 GB.
How can I select the higher ends board without looking at the price? Which specification should I check? For me all this motherboards looks the same with differences only on dissaptor/wifi and some port.
Hi Guys,
  • MSI X570-A PRO
  • MSI X570 TOMAHAWK
  • MSI MEG X570 ACE
This one is good...
Type|Item|Price
| Total | €511.99
Storage
8 x SATA 6Gb/s port(s),
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
Support Raid 0, 1, 10
https://rog.asus.com/in/motherboards/rog-crosshair/rog-crosshair-viii-dark-hero-model/spec
