G
Guest
Guest
Archived from groups: alt.comp.periphs.scanner (More info?)
Hi,
I got a Konica Minolta Dimage Scan Dual IV last week and installed
drivers on a W2K computer before connecting the scanner. All worked
well and within minutes I was scanning slides. After a few scans the
scanprogressbar stopped moving and after waiting some more I could
just kill the scan application. After this it was impossible to get
the scanner to work again. I uninstalled all soft, reinstalled and got
the same problem.
The scanner is OK as I installed everything on a Win98Se laptop and
all works as expected.
I did notice that the registry entries are not removed after an
uninstall on the W2K machine. I tried to delete the entries manually
but I get an errormessage saying that the entries can't be removed. I
tried a registry cleaner... all to no avail. I have admin rights (but
the partition is FAT32 anyway)
Re-installing the drivers works without error but as soon as I connect
the scanner there is a 'unknown device' under the USB controllers tab
in device manager.
Anyone has any ideas how to get this solved? (the laptop is way too
slow and only USB1.1 and I have 1000's of slides to go) :-(
Thanks in advance.
Bye Maurice
Hamradio: ON4BAM / M0CIL / 9H3Z http://www.on4bam.com/
Travelstories from Alaska, Scotland, South Africa,Iceland,
Faroe Isl., Australia, Norway, Svalbard and IOTA activations
Hi,
the same problem.
in device manager.
Thanks in advance.
Bye Maurice
