Archived from groups: alt.sys.pc-clone.dell (
More info?)
All these name brand computer companies kill themselves by coming up with
different part numbers for the same physical part installed in a different model
of computer. And, of course, they assign different part numbers to physically
identical parts made by different manufacturers. This complicates the
management of spare parts inventory, and adds greatly to the cost of stocking
spares. Must be something I do not understand about the manufacturing mentality
that drives this need to assign unique part numbers. Even with cross-references
for identical parts, it's a nightmare.
I've run into the same problem trying to decipher and use spare parts for DEC
(R.I.P.) and Compaq (double R.I.P.) computers. Compaq has used the same 1.44"
floppy drive without a front bezel and with a rounded eject buttom forever. A
1.44" floppy from a 1994 model Compaq will drop right into a two-year old
computer. But there must be 30 or 40 different part numbers for Compaq 1.44"
floppy drives. Maybe more. And then I get calls and emails from spare parts
houses looking for the EXACT part number, and a perfect physical replacement
will not do... Ben Myers
On Mon, 23 Aug 2004 20:31:12 -0500, "S.Lewis" <stew1960@cover.bellsouth.net>
wrote:
>"Greg" <nospam@noreply.com> wrote in message
>news:10ikvll9rkps394@corp.supernews.com...
>> I'm on my second phone call to Dell Spare Parts and service. I need the
>> cooling fan/shroud located on the rear of the machine which directs air to
>> the CPU. The fan bearings are noisy and getting noiser, and should it fail
>> the obvious happens.
>> Can anyone give me an alternative fan replacement for Dell p/n 5U059?
>> Thanks in advance,
>> Greg
>I'm not sure if you're looking for a third-party solution or another Dell
>part. If it's the latter, try D/PN D1592. That should get you the fan and
>plug, shroud, and housing. Snap it in and go. The same part has a variety
>of part numbers depending on the age of the machine. The specs. seem to be
>identical - though I can't recall if the fan maker is or not.
>Stew
