G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hi, A friend is having a problem with their conexant modem and connecting to
aolhell. The modem does not dial out it reports as not connected or in use.
Dell diagnostics fails and reports modem is in use by another program or
cannot open that port. It is set to com3, which appears correct and shows
no conflicts. I tried to right click and close all the systray clock items,
but no luck.
Funny thing is in msconfig selective startup is checked and only load system
services is checked. All of the rest, system.ini, win.ini and startup are
unchecked. I had them recheck at least startup, but that didn't work. They
said they never touched msconfig, but obviously someone did! Could this be
the problem? Uninstall AOLhell and reinstall? Replace modem? Any
thoughts? Thanks.
Pat Conover
pat conover at comcast dot net
but no luck.
thoughts? Thanks.
Pat Conover
