G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Having kind of a weird problem and not sure of the solution. Recently I all
of a sudden had trouble turning on my computer (Dimension 8300 XP SP2). Had
to hold the power button in for as much as twenty or thirty seconds before I
could power up. Tried some different things and found that plugging into a
different port on my USP seemed to fix the problem. Two days later the
problem started up again. Took the computer off the UPS and plugged
directly into a power strip. This seemed to fix the problem and then two
days later the same problem reoccurred. I am at a loss as to what is going
on. What is most confusing is how when I plug the computer into a different
power outlet everything seems to be fine for a couple days and then the same
powerup problems resume. I have not made any changes to my system, have run
adaware and done a complete virus scan of my system. Any help would be
greatly appreciated.
Jack
Jack Ruetty
jruetty@columbus.rr.com
Jack
Jack Ruetty
