Archived from groups: alt.sys.pc-clone.dell (More info?)
Could we please have some feedback on our choices? We would like to upgrade
our Dell 4550 to a Dimension 8400 which will be used mainly for video work
(using a Dell scanner to scan pictures, slides, etc.). We currently use a
Dell external dvd burner using firewire. We are hoping this Dimension 8400
will help in creating home videos of family pictures using Movie Maker and
Roxio DVD Builder without shutting down periodically due to slowing down and
locking up.
In customizing this model
http://configure.us.dell.com/dellstore/config.aspx?c=us&cs=19&l=en&oc=D84SO&s=dhs#bottom_anchor
there are 4 items we would appreciate your feedback on:
1) Basic unit comes with .... FREE UPGRADE! 1GB Dual Channel DDR2 SDRAM at
400MHz (2x512M) (QUESTION: would 400mhz be much different than the 533mhz
option?) We are also thinking of adding a 512mb stick from our current
Dimension 4550 to increase the basic unit which might be 400mhz; would that
be compatible with 533? or would just adding the 512mb stick to the FREE
UPGRADE work just as well? ....... if you have thoughts on heat on this
setup, PLEASE share! Besides the RAM, the PC would have the 80gb internal
hard drive plus adding an internal 120gb drive, moving from the 4550.
2) video basic is....
128MB PCI ExpressT x16 (DVI/VGA/TV-out) ATI RadeonT X300 SE
(QUESTION: would X800 SE be a better choice?) i.e. would it help prevent
lockups?
3) basic processor is....
Pentium® 4 Processor 540 with HT Technology (3.20GHz, 800 FSB)
(QUESTION: would a 560, 3.6GHz, 800 FSB show enough improvement to justify
add'l $230?
4) basic monitor is 15" flat panel display...
(QUESTION: is there REALLY much difference between a 19" or a 20" flat
panel display?? (we want more than 15")
I hope most of this makes sense and we'd greatly appreciate any feedback.
We're hoping a newer model/motherboard will accomodate the heat factor, is
this necessarily true? Is there any way to know how many fans come with
this 8400 Model? The computer is seated in a deskside compartment with the
front totally open and the backside open where vents are located but still
there are lockups and slowing down with the video creation in Movie Maker,
especially when a movie is reaching the size of filling a DVD. Work is
being done in 1.5-2 hr. timeframes sometimes.
TIA for any help or ideas, suggestions.......... Katy
locking up.
lockups?
add'l $230?
