Dimension 9100 - No Sound
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Dell France shipped this PC with XP Pro in French, not the asked-for
English. They sent an English CD which I installed clean (format c:
NTFS) and everything was going swimmingly 'till I connected the
speakers and boom box; nothing.
Control Panel/Sound-and-Audio-Devices tells me there is "No Audio
Device".
I ran the Sound Blaster Audigy 2 ZS CD that came with the PC. It tells
me "Setup could not detect any Sound Blaster Audigy 2 ZS on your
system".
Any thoughts? Thanks.
<tom_nospam_ba@pobox.com> wrote in message
news:ush3h1lqe77tf650v8vckg71o3brtadddn@4ax.com...
> Device".
> system".
First, the obvious question. You're sure it has an Audigy card? If so, it
is possible it isn't seated right. Try reseating it.
Tom
On Sun, 28 Aug 2005 14:37:19 GMT, "Tom Scales" <tomtoo@softhome.net>
>> Device".
>> system".
>Tom
Thanks for the fast response Tom.
It's not a (PCI) card - it's one of these on-board jobbies.
In fact, I have two 9100s here. The first was shipped with the wrong
processor and is awaiting pick-up. I just checked its entry in
Sound-and-Audio-Devices and it tells me it's "SB Audigy 2 ZS (CC80)".
I just tried downloading a beta driver from Creative (Beta driver with
OpenAL support) and I get the same "Setup could not detect any Sound
Blaster Audigy 2 ZS on your system" message when I run it.
news:mkj3h1l7sqpkseg2mhlt6ic1ndve0l7hh8@4ax.com...
>>> Device".
>>> system".
>>it
>>Tom
If it is onboard, it is not an Audigy 2 ZS
Looks like the driver is here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R107035&SystemID=DIM_P4_9100&os=WW1&osl=en&deviceid=8907&devlib=0&typecnt=1&vercnt=1&formatcnt=1&fileid=138503
You'll likely have to cut and paste it, as it will 'break'.
Tom
On Sun, 28 Aug 2005 16:00:51 GMT, "Tom Scales" <tomtoo@softhome.net>
wrote:
>:|http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R107035&SystemID=DIM_P4_9100&os=WW1&osl=en&deviceid=8907&devlib=0&typecnt=1&vercnt=1&formatcnt=1&fileid=138503
>:|You'll likely have to cut and paste it, as it will 'break'.
Hi, Tom
The other day I learned about TinyURL on this newsgroup. Try it, you
will like it.... it makes lo-o-o-o-o-ng URL addresses, well, tiny. Fer
instance, your link becomes: http://tinyurl.com/asmeg
Try it... you'll like it:
http://tinyurl.com/create.php
Best,
Andrew
Birmingham, Alabama, USA
rozsa@usa.invalid
"Andrew J. Rozsa" <rozsa@usa.invalid> wrote in message
news:8s14h1put7rhmubob76ij6t4kuagpnh4kl@4ax.com...
> Hi, Tom
> Best,
> Andrew
I'm familiar with it, but won't click any links using it. I have no way of
knowing where it will redirect me. If I can't see the domain name, I don't
click on a link. WAY too risky.
Tom
>>>> Device".
>>>> system".
>>>it
>>>Tom
Like I said above, on the first system Dell shipped, XP Pro sees SB
Audigy 2 ZS (CC80), and it too has onboard audio...
Now that hit the spot! It's not a Sound Blaster dirver, but I'm
audio-ing!! Many thanks, Tom.
news:7685h1ldt566f15496ptgqpv8nfca2aq51@4ax.com...
Happy to help.
