Dimensions of sugo sg07 power supply?
trypsta
7
Hello. I have looked everywhere for the dimensions for the power supply included in the sugo sg07 and can't seem to find an answer. Just want to know if I have the option of replacing it with say... a Corsair/Seasonic power supply or will I have to buy replacements from Silverstone.
Also I checked Silverstones website already and it just states custom power supply. Might just be shorter cables though.
D
The power supply is a full ATX unit with custom shorter cables. Any standard ATX power supply will work in the case although I recommend using a modular unit for maximum cable management.
http://www.bit-tech.net/hardware/cases/2010/06/28/silverstone-sugo-sg07-mini-itx-case-review/2
" The ATX power supply - yes, it's a full ATX power supply in there"
The unit that comes with the case is excellent just like most Silverstone power supplies. They are a brand I recommend by name.
http://www.hardwaresecrets.com/article/SilverStone-Sugo-SG07-Case-Review/1064/9
The power supply delivered up to 780 watts in Hardwaresecrets testing.
my mistake he is right. it has a full atx psu. so an atx PSU should do you just fine.
