DIRECT X HELP PLZ
Jameskitchen93
5
Hello
Sorry ive read the forum about dirext 9 because i have windows 7 now and i need to play games that require Direct X 9 ive tried everydownload tht is possible but doesnt work the problem i have is when i download it it says where to place extracted files and i dont kno where to put it and it has confused me for a week now and i dont kno whats going on so that i am able to start playing games tht require Dirext X 9 witch i already have Direct 11 on here
can u plz help me
Direct X setup has determined that a newer or equivalent version of direct X has been installed already, No instalation is necessary
I installed it then it said that i went to my game and it sed i dont have Direct X 9 installed still the problem there:S
1) Just want to make sure you ran the DX9 setup as an administrator.
2) Try running the game in XP compatibility mode. (Go to the primary game executable, right-click>Properties>Compatibility tab.)
3) Do you have the latest drivers for your video card?
4) What game is failing? And is it failing when you try to install the game, or run it?
??? how do i do that:S do u have msn or anything that i can add you can talk to me on there so its easier and faster?
No it is an online game called Special force ive already downloaded the game i just cant loging because in order to play i need Direct X 9 witch pops out on the login place whene ver i click it to try play downlaoded the game fine its just this Direct X 9 that im having problems downloading to try and plya my game
Ok, so open up Windows Explorer and navigate to C:\Program Files if you're on a 32-bit system or C:\Program Files (x86) if you're on a 64-bit system. The installation folder of the game should be there. In that folder (the game's installation folder, that is) should be the game's executable to which you can apply the compatibility settings.
It shouldn't say that! There's nothing to extract for the download I pointed you to; it's just a program that you run. What are you trying to extract?
EDIT: I'm going to be busy for a while. Maybe someone else could help you in the meantime...
