Computer Is A HP Pavillion a1340n with Intel Pentium 4 windows XP
ati radeon xpress 200 video card.
And in control panel/device manager/ the display adapter option is not there so IDK what to do please please help!
The system is using the generic video driver. Please install video driver provided by the hardware manufacturer.
To test DirectDraw functionality, click the "Test DirectDraw" button above.
Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer
System Information
Time of this report: 9/8/2013, 22:38:45
Machine name: JUDY-F9E8DD54AE
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.130704-0421)
Language: English (Regional Setting: English)
System Manufacturer: n/a
System Model: n/a
BIOS: n/a
Processor: Intel(R) Pentium(R) 4 CPU 3.20GHz (2 CPUs)
Memory: 1984MB RAM
Page File: 727MB used, 3148MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 10.0 (4.10.0000.5515)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The system is using the generic video driver. Please install video driver provided by the hardware manufacturer. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: n/a
Current Mode: 1024 x 768 (32 bit) (1Hz)
Monitor:
Monitor Max Res:
Driver Name: vga.dll
Driver Version: 5.01.2600.0000 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 7/27/2007 05:00:00, 9344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: vga.sys
Mini VDD Date: 4/13/2008 11:44:40, 20992 bytes
Device Identifier: {D7B70EE0-4340-11CF-B063-282AAEC2C835}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio rear output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0882&SUBSYS_103C2A31&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5172 (English)
WHQL Logo'd: Yes
Date and Size: 9/23/2005 18:56:28, 3966976 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Line in/Mic in
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: HID-compliant device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x006D
FF Driver: n/a
Device Name: HID-compliant consumer control device
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0745
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4375
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 11:45:37, 59520 bytes
| Driver: usbd.sys, 7/27/2007 05:00:00, 4736 bytes
Gameport Devices
+ PCI standard PCI-to-PCI bridge
| Matching Device ID: pci\cc_0604
| Service: pci
| Driver: pci.sys, 4/13/2008 11:36:44, 68224 bytes
+-+ Game port for ESS
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 4/13/2008 11:45:29, 10624 bytes
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/13/2008 11:39:48, 14592 bytes
| Driver: kbdclass.sys, 4/13/2008 11:39:47, 24576 bytes
| Service: kbdhid
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 4/13/2008 11:39:47, 23040 bytes
| Driver: mouhid.sys, 7/27/2007 05:00:00, 12160 bytes
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
System Devices
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_2A31103C&REV_80\4&B4B0D3&0&30A4
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 11:46:18, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 11:46:18, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 11:51:25, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 11:51:25, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 06:46:40, 6400 bytes
Name: Realtek RTL8139/810x Family Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_2A31103C&REV_10\4&B4B0D3&0&28A4
Driver: C:\WINDOWS\system32\DRIVERS\Rtnicxp.sys, 5.717.0309.2009 (English), 3/9/2009 05:03:24, 121984 bytes
Driver: C:\WINDOWS\system32\RtNicProp32.dll, 1.02.0000.0003 (English), 3/3/2009 12:18:04, 73728 bytes
Name: Game port for ESS
Device ID: PCI\VEN_1002&DEV_5A61&SUBSYS_2A31103C&REV_00\4&1CF2FBB4&0&2808
Driver: C:\WINDOWS\system32\DRIVERS\gameenum.sys, 5.01.2600.5512 (English), 4/13/2008 11:45:29, 10624 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1002&DEV_5A3F&SUBSYS_00000000&REV_00\3&267A616A&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/13/2008 11:36:44, 68224 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1002&DEV_5A33&SUBSYS_00000000&REV_01\3&267A616A&0&00
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_1002&DEV_437B&SUBSYS_2A31103C&REV_01\3&267A616A&0&A2
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/13/2008 09:36:05, 144384 bytes
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1002&DEV_437A&SUBSYS_2A31103C&REV_80\3&267A616A&0&88
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/13/2008 11:40:29, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 11:40:30, 96512 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 7/27/2007 05:00:00, 3328 bytes
Device ID: PCI\VEN_1002&DEV_4379&SUBSYS_2A31103C&REV_80\3&267A616A&0&90
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_4377&SUBSYS_00000000&REV_80\3&267A616A&0&A3
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 11:36:41, 37248 bytes
Device ID: PCI\VEN_1002&DEV_4376&SUBSYS_2A31103C&REV_80\3&267A616A&0&A1
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4375&SUBSYS_2A31103C&REV_80\3&267A616A&0&99
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/13/2008 11:45:35, 17152 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 11:45:36, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/13/2008 17:12:08, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 11:45:37, 59520 bytes
Device ID: PCI\VEN_1002&DEV_4374&SUBSYS_2A31103C&REV_80\3&267A616A&0&98
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4373&SUBSYS_2A31103C&REV_80\3&267A616A&0&9A
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 11:45:35, 30208 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/13/2008 17:11:54, 7168 bytes
Name: Compaq Deskpro Thermal Sensor
Device ID: PCI\VEN_1002&DEV_4372&SUBSYS_2A31103C&REV_81\3&267A616A&0&A0
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4371&SUBSYS_00000000&REV_80\3&267A616A&0&A4
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:51 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:51 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 7/27/2007 05:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:51 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:51 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:51 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 7/27/2007 05:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:51 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 7/27/2007 05:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 7/27/2007 05:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 7/27/2007 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 7/27/2007 05:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 7/27/2007 05:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 7/27/2007 05:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 17:12:17 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 17:12:17 17920 bytes
dpnet.dll: 5.03.2600.6311 English Final Retail 11/1/2012 19:02:42 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:09:20 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:09:19 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/13/2008 17:12:18 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 7/27/2007 05:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 7/27/2007 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 7/27/2007 05:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/13/2008 17:12:41 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 7/27/2007 05:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:12:02 35328 bytes
gameenum.sys: 5.01.2600.5512 English Final Retail 4/13/2008 11:45:29 10624 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 82432 bytes
system.dll: 1.01.4322.2503 English Final Retail 7/12/2013 03:15:53 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 8/15/2013 13:42:43 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 8/15/2013 13:42:38 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 8/15/2013 13:42:39 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 8/15/2013 13:42:39 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 8/15/2013 13:42:40 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 8/15/2013 13:42:40 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 8/15/2013 13:42:40 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 8/15/2013 13:42:41 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 8/15/2013 13:42:41 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 8/15/2013 13:42:41 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 8/15/2013 13:42:43 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 8/15/2013 13:42:43 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 8/15/2013 13:42:44 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 8/15/2013 13:42:44 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 8/15/2013 13:42:44 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 8/15/2013 13:42:43 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 8/15/2013 13:42:43 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 8/15/2013 13:42:42 223232 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:52 2113536 bytes
mfc40.dll: 4.01.0000.6151 English Beta Retail 9/17/2010 23:53:25 954368 bytes
mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 06:33:55 978944 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/13/2008 17:12:10 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/13/2008 17:11:49 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/13/2008 17:11:51 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/13/2008 17:11:52 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/13/2008 17:11:56 35328 bytes
mpg2splt.ax: 6.05.2600.6333 English Final Retail 1/1/2013 23:49:10 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/13/2008 17:11:59 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:53 20480 bytes
qasf.dll: 9.00.0000.4503 English Final Retail 4/13/2008 17:12:03 237568 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/13/2008 17:12:03 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/13/2008 17:12:03 279040 bytes
qdvd.dll: 6.05.2600.6169 English Final Retail 11/3/2011 08:28:36 386048 bytes
qedit.dll: 6.05.2600.6404 English Final Retail 6/4/2013 00:23:02 562688 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 10:21:32 733696 bytes
quartz.dll: 6.05.2600.6333 English Final Retail 1/1/2013 23:49:10 1292288 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 01:00:21 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/13/2008 17:12:42 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/13/2008 17:12:42 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/13/2008 17:11:55 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/13/2008 17:11:55 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/13/2008 17:11:55 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/13/2008 17:11:55 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/13/2008 17:11:55 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/13/2008 17:12:42 154624 bytes
mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 02:01:48 204800 bytes
ks.sys: 5.03.2600.5512 English Final Retail 4/13/2008 12:16:36 141056 bytes
ksproxy.ax: 5.03.2600.5512 English Final Retail 4/13/2008 17:12:42 129536 bytes
ksuser.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:11:56 4096 bytes
stream.sys: 5.03.2600.5512 English Final Retail 4/13/2008 11:45:16 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/13/2008 11:39:50 5376 bytes
mspqm.sys: 5.01.2600.5512 English Final Retail 4/13/2008 11:39:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/13/2008 11:39:52 7552 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 4/13/2008 11:39:53 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/13/2008 17:12:42 118272 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/13/2008 17:12:01 1428992 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/13/2008 17:12:42 30208 bytes
msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 10:11:44 17920 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/13/2008 17:12:10 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6333
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8117.0416
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8117.0416
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6333
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.4503
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6333
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6333
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.6076
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
HP Frame Grabber Filter,0x00200000,1,1,hpqdsftr.ax,45.04.0157.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6333
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.6333
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6333
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.4503
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6333
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.4503
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.6076
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6333
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6333
File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8117.0416
LEAD MCMP/MJPEG Codec,0x00100000,1,1,LCodcCMP.dll,1.00.0000.0021
LEAD MCMP/MJPEG Decoder,0x00800000,1,1,LCodcCMP.dll,1.00.0000.0021
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.4503
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6333
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.6404
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.6404
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.6076
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6333
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6333
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6333
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6333
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6333
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6333
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6333
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6333
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6333
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6333
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.6333
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6333
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6333
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6333
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.6333
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6333
Audio Capture Sources:
Line in/Mic in,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.6333
WDM Streaming Capture Devices:
Line in/Mic in,0x00200000,1,1,,5.03.2600.5512
WDM Streaming Rendering Devices:
Realtek HD Audio rear output,0x00200000,2,1,,5.03.2600.5512
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.6161
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.6161
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.6161
Audio Renderers:
Realtek HD Audio rear output,0x00200000,1,0,quartz.dll,6.05.2600.6333
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.6333
DirectSound: Realtek HD Audio rear output,0x00200000,1,0,quartz.dll,6.05.2600.6333
WDM Streaming System Devices:
Line in/Mic in,0x00200000,4,1,,5.03.2600.5512
Realtek HD Audio rear output,0x00200000,14,1,,5.03.2600.5512
System Information
System Model: n/a
BIOS: n/a
Memory: 1984MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: n/a
Monitor:
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n/a
Mini VDD: vga.sys
Vendor ID: 0x0000
Device ID: 0x0000
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Registry: OK
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
| Service: pci
| | Service: gameenum
PS/2 Devices
| Service: kbdhid
| Service: kbdhid
| Service: mouhid
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
System Devices
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
