Direction for side mounted case fans?
HomerThompson
301
For side mounted case fans, I should obviously have them setup as intakes for blower style reference cooled graphics cards, correct? But what about for a video card using axial fan cooling that's dumping the heat back into my case? Seems like that would dump the heat downward towards my power supply at the bottom, so in that case am I better off positioning a side case fan near the video card as an exhaust? Seems like that would screw up cooling to the CPU at the top of the case though. But would using the side case fan as an intake create a lot of turbulence and trap the GPU's hot exhaust in the bottom of my case? Using an NZXT Source 210 with two 120mm intake fans at the front and a 120mm exhaust at back, but I can add two fans at the top and one at the side of the case also. Not sure if it makes more sense to go with a blower or axial cooled video card in this case.
