Directx 11 sound device
Jul 24, 2018
51
What does it mean by directx 11 sound device? Does my motherboard Gigabyte G31M-ES2C has it? I pre-purchesed https://store.steampowered.com/app/866800/The_Walking_Dead_The_Final_Season/ which has 'directx 11 sound device as system requirements, plz explain. My graphics card is GT 1030 gddr5.
What cpu? If it's a core 2 duo or better it should run that game no problem. The GT 1030 is a direct x 11 capable GPU, sound will at least work over HDMI. It should also work through the motherboards sound card if you are using headphones or something.
Thanks for your reply, I have core 2 duo E7500 and I will upgrade it to Core 2 Quad Q6600 as soon as I get it from amazon, but I am using the GT 1030 via a HDMI to VGA active converter as my monitor (S19F350) only has VGA port, can you plz confirm that it will work? I am using a headphone with mic currently.
Thank you for your reply, but can you confirm that sound will work via headphone, you are telling "sound should..", otherwise I will get a HDMI to VGA converter with audio port to plug my headphone to it, plz clarify, I am still confused.
Can you hear sound in any other modern games with your headphones? If so you will hear sound in that walking dead game.
I am not able to play any modern game with that spec, I play CS GO, Dota 2, Company of Heroes 2, Paladins etc
