DirectX 9.0c Problem
G
Guest
Guest
Archived from groups: microsoft.public.games (More info?)
I am using Windows XP Pro with all upgrades available from the Microsoft
Windows Update. Recently, I installed the DirectX 9.0c and some issues
appeared:
While running games (Half-Life for example) my computer started doing one of
two things after having played for some time (for how long I can play before
this happens seems random):
My PC spontaneously restarts (I see a flash of a blue screen with white
text, but the computer restarts so fast it's impossible to read what it says).
Or it simply closes the game I was running and returns to the desktop (I
have experienced this with Internet Explorer as well...).
I am using a GeForce2 MX/MX 400, with the latest software update from nVIDIA
installed
What is the problem? What can I do? There is no way to uninstall DirectX,
and I have already tried reinstalling both DirectX and my video card driver
but it doesn't fix the problem.
Major thanks in advance
Hi Kasper,
Your system is indeed restarting as a result of a STOP error.
To stop this behavior go to Control Panel / System / Advanced /
Click the Startup and Recovery Settings button / Uncheck the box
labeled "Automatically restart" under the System Failure section.
To analyze the error, try the steps in: http://aumha.org/win5/kbestop.htm
If the error indicates a file name that begins with ati, or nv (nVidia)
the most likely solution would be to *reinstall* the latest drivers using
the instructions at: http://mvps.org/nibblesnbits/Video.html#drivers
Cheers, Windows XP MVP Shell / User
Jimmy S. http://mvp.support.microsoft.com
Game FAQs: ;gms]http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my Zone.com / Gaming Helpsite: http://nibblesnbits.tk or Call / Contact
MS Support at: http://support.microsoft.com/default.aspx?scid=sz;en-us;top
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
"Kasper M." <Kasper M.@discussions.microsoft.com> wrote in message news:6FF3D08A-D574-4F34-8A08-C49E4F8A991C@microsoft.com...
| appeared:
| installed
Thanks...
Turning off the automatic restart enabled me to read the STOP-message, but I
am still unable to discover or fix the problem. This is what the message said:
Technical Information:
*** Stop: 0x0000008E (0xBF801ECF, 0xF3160C44, 0x00000000)
*** win32.sys address BF801ECF base at BF800000, datestamp 41107f7a
Can this help discover the problem?
Thanks a lot...
"Jimmy S." wrote:
> Hi Kasper,
> | appeared:
> | installed
This was followed shortly thereafter by another crash and the following
message:
The problem seems to be caused by the following file:
win32k.sys
PAGE_FAULT_IN_NONPAGED_AREA
Technical information:
*** Stop: 0x00000050 (0xE2357C74, 0x00000000, 0xBF8010FD, 0x00000000)
*** win32k.sys - Address BF8010FD base this at BF800000, Datestamp 41107f7a
And this time I wasn't even playing a game - merely using Internet Explorer,
and having MSN Messenger open.
Thanks for your assistance (If I am posting this in the wrong place please
inform me...)
Hi Kasper,
There's some ideas posted in this thread, does anything look familiar?
http://www.duxcw.com/yabbse/index.php?board=3;action=display;threadid=8622;start=15
Visit my MSN Zone.com and Gaming Help Site: http://mvps.org/nibblesnbits
MS Assisted Support: http://support.microsoft.com/select/?target=assistance
"Kasper M." <Kasper M.@discussions.microsoft.com> wrote in message news:48082600-5981-4CA8-8481-29C8F5CFBAB4@microsoft.com...
| Thanks...
| Thanks a lot...
| "Jimmy S." wrote:
| > Hi Kasper,
| > | appeared:
| > | installed
Well, the errors seem familiar enough, but I am still unable to fix the
problem. What should I try? And how do I disable BIOS shadowing if I am
unable to find such an option in my BIOS Setup Menu?
Thanks
"Jimmy S." wrote:
> Hi Kasper,
> | Thanks...
> | Thanks a lot...
> | "Jimmy S." wrote:
> | > Hi Kasper,
> | > | appeared:
> | > | installed
Hi Kasper,
Your motherboard manual should have that information, or you could
call the computer's support tech if it's a brand name system. There are
some suggestions on the KB link provided in the 2nd previous post if
you search for 0x0000008E at: http://aumha.org/win5/kbestop.htm
"Kasper M." <KasperM@discussions.microsoft.com> wrote in message news:A4C7143E-4207-4E1A-81D9-6BB90EA62CFF@microsoft.com...
| Thanks
| "Jimmy S." wrote:
| > Hi Kasper,
| > | Thanks...
| > | Thanks a lot...
| > | "Jimmy S." wrote:
| > | > Hi Kasper,
| > | > | appeared:
| > | > | installed
