Directx Problem need help !! urgent !
VIntoxicatedV
4
I just bought this game Elder Scrolls Online and i just heard that the game does not support DX9/10 .I got Nvidia Gefore 210 which can only run upto DX10.1 my computer specs are :
Processor: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (4 CPUs), ~3.1GHz
Memory: 8192MB RAM
Motherboard: Asus P8 H61-M LX3
The my CPU and RAM can handle the game easily but its impossible to to run the game now as it is not compatible with DX10 ,The game was compatible with DX9/10 before they updated it .
I heard people tried using dxcpl but the error still showed up
My computer can handle the game all i need is a way to pass the error screen .
Is there anyway to fix this without buying a new graphics card ?? i cant afford a new one :(
Your card does not support past DX 10, solution is to replace the card. Your 210 card is probably slower than the onboard video in your CPU anyway, good time to upgrade. GT 730 GDDR5 is a huge upgrade and you can find those pretty cheaply.
