Disable Integraded graphics problem.
taby448
8
I want to disable my integrated gpu, which is an intel integrated 4000... i want to switch it to the dedicated amd r9 m275x
This is on a lenovo Y40. in the bios i found switchable graphics and UMA. UMA disables one, which turns out to be the dedicated. how do i change that? ;-;
Leave things alone. The machine will switch automatically between graphics sources according to demand e.g. on board for office work and AMD for viewing a film
should i disable the integrated, and keep in mind this is a laptop.
As both gpus are in, how do i enable dedicated graphics on the UMA settings in bios? there is switchable. which i hate... and UMA.
which then puts me into the integrated only,
the reason why i want to wipe off the integrated, is because it forces me to use it in minecraft no matter what, as for it uses a launcher in to javaw.exe which causes a loop into a forced integrated gpu
