disabled keyboard problem
kumayadavr
Commendable
Jan 24, 2018
4
hi, i have disabled my keyboard by mistake on start up menu. so my keyboard is not working so how should i enable it
If they keyboard even doesn't work in BIOS settings and it's not disabled in BIOS settings then I would try another keyboard. It sounds like it may have died possibly.
- Does the keyboard work in BIOS settings?
- Does your mouse still work? If so you can use on screen keyboard to at least get around Windows for the time being.
- What start menu setting do you think disabled your keyboard? I've never heard of any way to disable a keyboard that easily. It sounds like Windows is having an issue with your keyboard.
No,the keyboard doesn't work in BIOS settings.
My mouse still works and from BIOS settings only i have disabled my keyboard
