Is it possible to disable front case fan via bios or something when its not plugged to any pin slot on motherboard(its connected with psu(4 pin big cable) via switch, not directly to motherboard.(its K58 case). I currently keep it disconected, because it goes at full speed all the time.
f its not possible what case fan do u recommend(i think it is 140mm frontfan) and does it matter if its 4 or 3 pin? My back case fan has 3 pins, but its regulated via AI 3.
