Disabling wireless radio broadcasting when not required
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.internet.wireless (More info?)
I would like to buy a Wireless ADSL Router with 4-port switch.
Is this possible to disable the wireless radio broadcasting when no
wireless connection is required?
I do not need permanetly the signal broadcasting, but only when I use
my notebook in other rooms. But the router should continue to work for
all other wired PCs in my wired LAN.
Is this possible?
In short: can I have wired connection enabled and wireless connection
disabled at the same time?
Is there any model that allows that?
Thank you very much for replying.
>Is this possible?
If I take the effort to log into the http-based control for my D-Link
624 and click the wireless button, there is a selection for Wireless
On/Off. I assume most wireless routers have the same thing. Obviously
you can only get there from a wired PC to turn it back on.
Hmm. I just had a thought. One day I'll have to see what happens if I
turn off wireless on the router and then power cycle it.
On PCs with wireless cards, you can disable wireless either from the
card's control software or the Windows Network Setup for wireless. Don't
know about the other OSs, but you didn't ask about this end anyway.
>Is this possible?
I assume by "broadcast" you mean disabling the wireless portion and
not mean anything in reference to disabling SSID broadcasting.
The easy solution is to simply remove the antenna(s) from your
wireless router when not in use. Look for a router with R-TNC
(Linksys) or R-SMA (D-Link) connectors. This gets old very quickly.
Another kludge is to write a keyboard macro or script that simulates
diving into the routers HTML web page for turning on and off the
wireless enable/disable check box. This is not as difficult as it
seems and can be done with any macro recorder or HTML automation
software.
What you're asking is a common problem at internet cafe's and
restaurants. They want to turn off the wireless after approximately
6PM so that the geeks don't monopolize the tables during prime time.
However, they want the back office computah to continue normal
operation.
I go for the divide and conquer solution. Don't buy an all in one
box. Buy three separate boxes. Box one is an ADSL to ethernet
modem/bridge. It's always on. Box two is an ethernet router. It's
also always on allowing the local wired PC's to operate. Box three is
a wireless bridge also known as an "access point". This is on only
when needed. This arrangement also has the advantage of locating the
router/switch in the back office where one can make a mess with CAT5
wires going everywhere, while the wireless bridge can sit high up in
the public area for better coverage. Turning off the power to the
wireless bridge does not affect anything in the ethernet router.
Incidentally, a wireless router can often be used as a wireless bridge
by ignoring the WAN port. You may wanna buy a wireless router instead
of a wireless bridge (access point) because they're often cheaper and
offer the versatility of being used as either a router or bridge
depending on wiring and configuration.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
> Is this possible?
Yes, several models can do this; but it's not as simple as flipping a
switch on the unit. You have to reconfigure and (usually) reboot the
router every time you switch the wireless function on or off. It would
be easier, though more expensive, to use a separate wireless access
point connected to an always-on wired router. Whichever method you
choose, you should configure the wireless device for automatic channel
selection in order to avoid intermittent interference with other
wireless networks in your vicinity.
On Mon, 28 Jun 2004 14:09:02 GMT, neillmassello@earthlink.net (Neill
>> Is this possible?
On my Toshiba, it's not as simple as flipping a switch, but almost. I
have to log into the router, uncheck the wireless box, and log out
again. Only takes a few moments, and I don't do it often.
Dick
WWVzLCBzdXJlLg0KDQpNb3N0IHdpcmVsZXNzIHJvdXRlcnMgc3VwcG9ydHMgdGhhdCBmdW5jdGlv
bi4NCiJkaXNhYmxlIHNzaWQgYnJvYWRjYXN0aW5nIiBvciBzb21ldGhpbmcgdG8gdGhhdCBlZmZl
Y3QuDQoNCiJHaW9iaWJvIiA8Z2lvYmlib0B5YWhvby5jb20+IHdyb3RlIGluIG1lc3NhZ2UgbmV3
czpqOXF2ZDA5cGk2ZXEwZXJuOHV0Nm1oNzJ2YXZmcGdqM3UzQDRheC5jb20uLi4NCj4gSSB3b3Vs
ZCBsaWtlIHRvIGJ1eSBhIFdpcmVsZXNzIEFEU0wgUm91dGVyIHdpdGggNC1wb3J0IHN3aXRjaC4N
Cj4gDQo+IElzIHRoaXMgcG9zc2libGUgdG8gZGlzYWJsZSB0aGUgd2lyZWxlc3MgcmFkaW8gYnJv
YWRjYXN0aW5nIHdoZW4gbm8NCj4gd2lyZWxlc3MgY29ubmVjdGlvbiBpcyByZXF1aXJlZD8NCj4g
DQo+IEkgZG8gbm90IG5lZWQgcGVybWFuZXRseSB0aGUgc2lnbmFsIGJyb2FkY2FzdGluZywgYnV0
IG9ubHkgd2hlbiBJIHVzZQ0KPiBteSBub3RlYm9vayBpbiBvdGhlciByb29tcy4gQnV0IHRoZSBy
b3V0ZXIgc2hvdWxkIGNvbnRpbnVlIHRvIHdvcmsgZm9yDQo+IGFsbCBvdGhlciB3aXJlZCBQQ3Mg
aW4gbXkgd2lyZWQgTEFOLg0KPiBJcyB0aGlzIHBvc3NpYmxlPw0KPiANCj4gSW4gc2hvcnQ6IGNh
biBJIGhhdmUgd2lyZWQgY29ubmVjdGlvbiBlbmFibGVkIGFuZCB3aXJlbGVzcyBjb25uZWN0aW9u
DQo+IGRpc2FibGVkIGF0IHRoZSBzYW1lIHRpbWU/DQo+IA0KPiBJcyB0aGVyZSBhbnkgbW9kZWwg
dGhhdCBhbGxvd3MgdGhhdD8NCj4gDQo+IFRoYW5rIHlvdSB2ZXJ5IG11Y2ggZm9yIHJlcGx5aW5n
Lg0K
Walker wrote:
<top post corrected>
> Most wireless routers supports that function.
> "disable ssid broadcasting" or something to that effect.
Disabling broadcasting of the SSID does _not_ stop broadcasting.
The radio is stil active and still sending out the same amount of
beacon frames.
Only inside those beacon frames the SSID is now missing.
Sander
On Mon, 28 Jun 2004 18:09:39 +0800, "Walker" <abc@xyz.com> wrote:
>Yes, sure.
Thank you for your reply.
But "disable ssid broadcasting" will disable only the sending of some
information, but the router will still broadcast a radio signal.
I want to turn off the brodacasting completely
(ok, may be I coulkd remove the antenna 🙂, but is there any
"standard" way to do that?)
>>Yes, sure.
My Toshiba router/cable modem has an option in the wireless setup
screen to turn wireless off. That is the default setting when the
router is reset. There is no question that it does turn it off.
I just read through the manual for the LinkSys WRT54g, a popular
router, and in the wireless screen there is an option to set wireless
Mode to Mixed, G-Only or Disabled. I would assume many routers have
this same capability.
Dick
> Dick
I guess this is your Toshiba notebook, must notebooks now have this options
because there are certain environments where people don't want the radio
signals as its a type of interference eg Hospitals, airplanes etc
regards
Andrew
http://www.securelymobile.co.uk/
Suppliers of Security, Wireless and Mobile Computer and Communication
Solutions.
On Mon, 28 Jun 2004 18:42:07 +0100, "Andrew Crook"
>> Dick
>regards
>Andrew
No. This is a Toshiba PCX5000, which is a cable modem and wireless
router in the same box. It's true that I can turn off the internal
wireless in my HP laptop, but that doesn't stop the router from
transmitting.
Dick
I don't see my Dlink DI-524 having the wireless off button but I could
reduce the signal down to 10%. Personally I would just get a new router and
enable WPA & MAC filtering and not worry about it after that. Unless your
neighbor is a creative hacking genius he ain't getting in. Its my
understanding that there isn't a KNOWN way of sniffing in on a WPA signal.
"xray" <notreally@hotmail.invalid> wrote in message
news:v4svd017h5qiro84ooa0gea5oqumbnfsht@4ax.com...
> >Is this possible?
> Is this possible?
ZyXEL Zyair B-2000 v2 has this functionality. ($109 direct from mfg.)
Lac
the easiest way to do this is simply buy a standard wired only router and a
wireless access point (WAP) and connect the wap to one of the ports on the
switch. Then when you want to disconnect the wireless access, just unplug
the wap. HOWEVER, this is a lot of extra work, since with the proper
settings with either a WAP or wireless router, there is no real reason to
disable the wireless access when you are not using it.
"Giobibo" <giobibo@yahoo.com> wrote in message
news:j9qvd09pi6eq0ern8ut6mh72vavfpgj3u3@4ax.com...
> Is this possible?
