Alright, first of all, here is my full part list: https://pcpartpicker.com/user/cameron13x/saved/QXbQZL
So, I had my cousin over today (who has recently completed his first build, and is pretty knowledgeable,) and we disassembled my pc, trying to figure out the culprit(s). We think the issue may be the cpu socket, the cpu, or the monitor (as it will not post anything.) The cpu indicator is the only one that turns on, so I know that the ram, ssd, and most likely gpu are fine. All of the lights turn on, including the case fans, cooler, and gpu lights. Some potential concerns I have are:
1. There was a very small amount of thermal paste in my cpu socket, not even covering any pins.
2. There was a smidgen of thermal paste on my motherboard.
3. One of the motherboard standoffs could not go in, as the pre-installed piece attached to the case would not allow it to be screwed in.
4. I put my cpu and cooler in, and the cpu will not work.
5. I connected the HDMI from the monitor to the gpu, then tried the motherboard, and nothing would post.
6. My psu is only 650 watts, and the recommended is 750 watts.
7. The cpu is fused to the heatsink.
8. I have already (successfully) RMA'd one cpu.
Any advice will help, and if anyone successfully undermines the issue, I will gladly give some coins, thank you.
There will be images of some of the issues on my profile.
