Screws? You mean plastic clips, right?
OK there were basically 2 ways to attach them, with clips or with no hardware. And no hardware attachment means they had to use glue.
Now, since you actually had hardware attaching it, I have to assume it's simply stuck there now with Thermal Interface Material. This stuff is usually a type of putty, it's sticky and softens when warm. You can usually get it off the chip by applying a small amount of lifting force to break it free.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
