I noticed that there is a small collection of discolored pixels (a small dot about 5 pixels across) which is comprised of all colors, but they appear to change colors from different angles. Also I can feel with my fingernail that there is a small indentation right above this spot. I'm not sure if this discoloration if caused by the scratch due to the diffraction of light, or if the pixels are stuck. I assume this is caused by the scratch since stuck pixels don't change color from different viewing angles.
There is also another spot (separate from the one above) where there is a small horizontal black line also about 5 pixels across which is visible from only a short range of angles. Whether or not it's visible depends only on the vertical angle, since if I look from above or below, the spot disappears; there is only a short range between where the spot is visible briefly. Any advice in explaining the causes of these defects, and whether or not there is a solution to fix them is appreciated.
