Discoloration on my EKWB water block???
axlrose
2,057
4
19,815
Reapplying TP while taking the loop apart to add a GPU. Seems like there is discoloration inside. Might have been there before? Might be how it is supposed to look? Anything to cause concern before I put it back together?
I agree this looks like acrylic that is a little worn from use and heat. If you used any additives or special fluids they could be the cause as well....or if you ran straight distilled water it could be micro growth algae and/or other microbes. Did you flush your system regularly?
