Unfortunately, I am not able to use the first slot on my motherboard for my new card as my CPU cooler is too chonky and ends up touching the card. This got me a bit paranoid at the possibility that my card is being hampered by a lower bus speed.
My motherboard's manual: https://hostr.co/C6uAP84qrM91, seems to show that the second slot is also x16, but I know that there are some SLI nuances that affect bus speed that I do not fully understand.
Knowing that my understanding is limited, I tried a couple of approaches to confirm that my new card is running on the fastest bus. The problem here is that GPU-Z and Nvidia Control Panel do not agree on what my bus speed is.
GPU-Z claims that my pcie bus is x16: https://hostr.co/OGuPAQrpBhYs
Nvidia Control Panels says the bus is just x8: https://hostr.co/1YuYsxW2lJv6
Which of these two means should I believe? I checked in my motherboard BIOS as well and it says that the card is running at x16 PLX, so I am leaning to GPU-Z being the correct metric.
One last thing. I have a sound card inserted into slot 5 on my mobo ("PCIe 2.0 1.1 x4_1 slot"), would this interact with the bus speed of my GPU in slot 2 by any chance?
I appreciate any help you can offer. I just want to know that I am not hampering the performance of my new card because I do not understand the finer points of the PCie Bus interface and how other lanes interact.
