Hello,
I'm wondering if the disk is actually failing or if this is a power supply issue. Disk Sentinel says:
"There are 52 bad sectors on the disk surface. The contents of these sectors were moved to the spare area.
The drive found 1 bad sectors during its self test.
Problems occurred during the spin up of the disk 4 times. This can be caused by the disk itself or huge power load (weak power supply).
There are 1 weak sectors found on the disk surface. They may be remapped any time in the later use of the disk.
6100 errors occured during data transfer. This may indicate problem of the device or with data/power cables. It is recommended to examine and replace the cables if possible.
At this point, warranty replacement of the disk is not yet possible, only if the health drops further.
It is recommended to examine the log of the disk regularly. All new problems found will be logged there.
It is recommended to backup often to prevent data loss."
It says my disk health is currently ay 33%, which has me worried. Any help would be great. Thanks.
Operating System: Windows 7 Professional 64-bit (6.1, Build 7600) (7600.win7_gdr.110408-1633)
Language: English (Regional Setting: English)
System Manufacturer: Micro-Star International
System Model: PR201/PR321
BIOS: A1331IG6 Ver1.0N
Processor: Intel(R) Core(TM)2 Duo CPU T9400 @ 2.53GHz (2 CPUs), ~2.5GHz
Memory: 4096MB RAM
Available OS Memory: 4062MB RAM
Page File: 2363MB used, 5757MB available
Memory: 4096MB RAM
