Hi,
Sometimes when I boot my PC it freezes in the Windows logo, without the loading balls. I have to shut down my PC from the power button and start it up again until it starts working again. I had made a new fresh install of the Windows to the SSD.
I have tried to go through the Startup Repair, but it doesn't show any errors, but when I enter the Command Prompt from here:
and I type C: -> DIR , there is no files visible.
If I in the other hand when I type F: -> DIR , I get the usual Windows, Program Files etc. visible.
This is confusing, as while logged in Windows, the sub files Windows, Program Files etc. are located under C:\, and the System Reserved F:\ is empty (125MB free / 548MB) and yes I have selected show hidden files.
Here is a image from the Disk Management, for some reason there is C and F assigned in the Disk 0 (boot drive).
Here's a screenshot of the Disk 0 properties:
I hope to get help. If you need any more information, I'll give them. My Windows is in Finnish, but I can translate anything you need.
My PC Specs if needed:
Windows 10 Pro
AMD FX-6200
8GB RAM
750 Ti
Gigabyte GA-970A-UD3
1x Kingston A400 240 Gt (Main, boot drive)
1x Kingston SSDNow V+200 60GB (Secondary drive)
1x WD Green WD10EADS 1TB (Secondary drive)
Windows 10 Pro
AMD FX-6200
8GB RAM
750 Ti
