Disk recovery help
Peter Nutter
Hello, I formated my 1 TB hard disk, so I lost all of my files, is there some way to recover the files? I have been trying with Recua, disk drill and pandora. Thanks for your help. Sorry For My Bad English
depends on what you did to format the disk. something like a military wipe or boot-n-nuke would render them unrecoverable.
I use testdisk to reverse accidental formats. Success depends on what you did with the disk after formatting it though.
Hi there Peter Nutter,
The thing you've done is just an ordinary format. In case the data is not overwritten, you should be able to recover at least some of the data.
It is strange that the tools that you've mentioned are not working. I guess you can't do much except for trying some more data/partition recovery tools.
You can check the one that popatim suggested.
Cheers,
D_Know_WD
