So I installed a SSD and converted my existing HDD into an external device. The only problem is that I needed to format the drive first.
I didn't entirely understand the description for the clean command and ended up using the clean all command thinking it was what was needed to remove all partitions from the drive.
Here are the steps I took
-run CMD as admin
-diskpart
-list disk *drive I am formatting is disk 1*
-select disk 1
-clean all
I ended up closing out the window and restarting the PC to make sure I canceled the process, after rebooting I then redid all of the steps and simply left "all" off at the end. I then opened the partition manager, initialized the drive, and added a partition.
Now my concern is, I'm still not quite sure about the parameters of the clean all command and while doing research about it when trying to figure out why the process was taking so long I read where someone accidentally formatted their windows install drive using the command.
By doing it the way I did is there any chance that the clean all command touched data on my install drive, disk 0? I would assume that if it did the system would not have booted and it would show up as blank space in a partition manager since the process marked the drive as clear BEFORE writings everything to 0. Correct?
-run CMD as admin
-diskpart
-select disk 1
-clean all
