A abhishekmore525 Aug 20, 2018 9 0 10 Aug 20, 2018 #1 hi .there is problem in my laptop that it doesnt showing display adapter in device manager .i tried to download many driver but no use thats why im not able to reduce brightness and play games plz tell me what to do
mhtsgr999 Honorable Oct 21, 2013 104 1 10,710 Aug 20, 2018 #2 Go to manufactures website and Download the latest VGA drivers, Or tell us the EXACT model of the laptop so we can find it for you. Upvote 0 Downvote
A abhishekmore525 Aug 20, 2018 9 0 10 Aug 21, 2018 #3 mhtsgr999 : Go to manufactures website and Download the latest VGA drivers, Or tell us the EXACT model of the laptop so we can find it for you. bro i tried to install,but its not installing ,laptop acer aspire a315 -31 win 8.1 pro Upvote 0 Downvote
mhtsgr999 Honorable Oct 21, 2013 104 1 10,710 Aug 21, 2018 #4 What error you are getting when you are trying to install? Upvote 0 Downvote
A abhishekmore525 Aug 20, 2018 9 0 10 Aug 21, 2018 #5 mhtsgr999 : What error you are getting when you are trying to install? bro there is no option of display in device manager Upvote 0 Downvote
A abhishekmore525 Aug 20, 2018 9 0 10 Aug 21, 2018 #6 i tried to install it using add legacy hardware but it didnt worked Upvote 0 Downvote
mhtsgr999 Honorable Oct 21, 2013 104 1 10,710 Aug 21, 2018 #7 Try the Intel auto detect and see if it can find some drivers for you. https://downloadcenter.intel.com/download/24345/Intel-Driver-Support-Assistant Upvote 0 Downvote
A abhishekmore525 Aug 20, 2018 9 0 10 Aug 21, 2018 #8 mhtsgr999 : Try the Intel auto detect and see if it cant find some drivers for you. https://downloadcenter.intel.com/download/24345/Intel-Driver-Support-Assistant i also tried it but it said that all driver are up to date Upvote 0 Downvote
mhtsgr999 Honorable Oct 21, 2013 104 1 10,710 Aug 21, 2018 #9 Download DDU and uninstall the currently installed drivers for GPU in safe mode. https://www.guru3d.com/files-details/display-driver-uninstaller-download.html After that reinstall the drivers from auto detect or from the manufacturers support webpage. Upvote 0 Downvote
A abhishekmore525 Aug 20, 2018 9 0 10 Aug 21, 2018 #10 mhtsgr999 : Download DDU and uninstall the currently installed drivers for GPU in safe mode. https://www.guru3d.com/files-details/display-driver-uninstaller-download.html After that reinstall the drivers from auto detect or from the manufacturers support webpage. Upvote 0 Downvote
A abhishekmore525 Aug 20, 2018 9 0 10 Aug 21, 2018 #11 there is no driver showing AND if i uninstalled current driver it will went black screen ? Upvote 0 Downvote
A abhishekmore525 Aug 20, 2018 9 0 10 Aug 21, 2018 #12 mhtsgr999 : Download DDU and uninstall the currently installed drivers for GPU in safe mode. https://www.guru3d.com/files-details/display-driver-uninstaller-download.html After that reinstall the drivers from auto detect or from the manufacturers support webpage. DDU plz elaborate bro cant able to find ddu Upvote 0 Downvote
A abhishekmore525 Aug 20, 2018 9 0 10 Aug 21, 2018 #13 mhtsgr999 : Try the Intel auto detect and see if it can find some drivers for you. https://downloadcenter.intel.com/download/24345/Intel-Driver-Support-Assistant i tried to uninstall but still no effect on system bro..now im getting frustrated with it Upvote 0 Downvote
