Display corruption DVI-I / GPU / Monitor
antonnortivirus
Hi,
I have an odd problem here.
A few weeks ago after booting up my pc the BIOS and Windows screens were very "corrupted" looking... The screen was split into thirds with lots of fuzzy artifacts jumping about.
After 2/3 restarts the display then failed to come alive at all.
This was remedied by a new DVI cable and has been fine since.
Last night after updating my GPU drivers, the same issue presented itself.
I am a bit confused as to where the problem is. A new cable might sort the issue again but is there something underlying?
Monitor: Yamkasa Sparta 301 30"
GPU: Palit GTX780ti (Dual DVI only) (344.48 Drivers)
PC:
i7 4770K Overclocked to 4.4GHz
16GB RAM
H105 WaterCooling
600W PSU
Win 7
Yeah... I mean obviously it is a budget display.
The first time it happened I had the ability to test the card / cable out on a different monitor and no problems.
I am going to try another cable out and see if that resolves the issue - thankyou for the NewEgg link... Someone mentioned the screws and TBH the cable port is in a terrible place and may have come loose I suppose.
