Display Driver Amd Stopped Responding And Has Recovered ! HELP !!
Danial isaac
49
My Spec
Processor: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz (4 CPUs), ~3.1GHz
Power Supply : Cooler Master GX550W
GPU:Sapphire HD 7770 Vapor-X GDDR5
Ram:8GB Kingston
MOBO:Asus P8H61-M Plus V3
I have some problem with my computer ...
When im playing game like Farcry 3,Battlefield 3/4 ,Assasin Creed BF 4, COD Ghost ,Black OPS 2
About 30 minutes playing the game suddenly my computer freeze and my monitor like restarting and theres pop up say Display Driver Amd Stopped Responding And Has Recovered .
First of all i try touch my gpu not hot and i see MSI Afterburner
the GPU temperature is arround 60-69.So do anyone know how to fix/solved this type of problem ..
And someone can help me Find graphics card BIOS for this card?
Pleaaasee ...
Just trying to reinstall won't work in many cases. You need to uninstall first, like Suztera said, and THEN reinstall. Try downloading the files from the following two links and then running the display device driver uninstaller. After it's done, reboot and THEN reinstall the catalyst control center driver.
Display driver uninstaller:
http://www.guru3d.com/files-get/display-driver-uninstaller-download,9.html
AMD catalyst control center 14.4:
http://support.amd.com/en-us/download/desktop?os=Windows%208.1%20-%2064#amd-catalyst-packages
I already make reinstall my gpu driver about 3 times but it still the same ..
I already search tutorial how to fix this problem but this the same too .. nothing change ..
Hope theres any best solution ?
