Display Driver Issues with Radeon 6850
gunraidan
11
So this is the deal:
I started getting a message saying "AMD Display Driver Needed to be Reset"
So I thought "no biggie", but then when I booted into Windows I just got a black screen with an occasional flash before. The system works fine under safe mode and works fine once I delete all of AMDs drivers. However once I install the AMD Display driver the problem persists. Even when going under Catalyst install and checking every box but "AMD Display Driver" the computer works fine. So I decided to do a fresh clean install of Windows and the problem seemed fix. However after two days the problem is here yet again with the same symptoms.
What exactly is going on?
Specs:
Windows 7 64-Bit
AMD Radeon 6850
Intel i55 2500k
2x4GB of RAM (8 total)
120GB OCZ Agility 3
So I did a fresh install of Windows 7. After turning Windows Update off and only installing the essential drivers for my motherboard (USB3 and LAN) I install the newest, just came out today, drivers from AMDs site. What happens? The EXACT same thing. This is ridiculous.
Could this be hardware related?
