Display issue problem
Primalchaos20
Commendable
Dec 13, 2016
Asus extreme motherboard z170
ntel Core i7 6700K 4.00 GHz Unlocked Quad Core Skylake Desktop Processor, Socket LGA 1151
EVGA SuperNOVA 850 G3, 80+ GOLD 850W, Fully Modular, EVGA ECO Mode with New HDB Fan, 10 Year Warranty, Includes FREE Power On Self Tester, Compact 150mm Size, Power Supply 220-G3-0850-X1
Samsung 850 EVO 1TB 2.5-Inch SATA III Internal SSD (MZ-75E1T0B/AM)
Corsair LPX 32GB 2 x 16GB Memory
WD Black 5TB Performance Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 128MB Cache 3.5 Inch - WD5001FZWX
Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler , Black
ASUS GeForce GTX 1080 8GB ROG STRIX Graphics Card (STRIX-GTX1080-A8G-GAMING)
I'm running those components on my pc.
I'm having issues with display. So every time I try to connect my pc to the monitor it won't send a display signal at all Motherboard shows a q code of 99. But when I take my gpu out my display works for some reason. Anyone know what's wrong and help me out thanks
Did you plug all power connectors on both the VGA and the motherboard?
If so, boot without the card go to the BIOS and select 'Load Default Configuration' save and restart. Before the PC boots replace the VGA and see if it works now.
If that doesn't work either, try a different VGA port on the GTX1080. It is not uncommon for the ports to work in a specific order (eg. if you plug the monitor in DisplayPort 1 it will not work, if you plug it in DP 2 or 3 it works fine).
